Home > Technical (L322) > DPF ADVICE PLEASE... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
just run as you do now....if and when the yellow dpf warning comes up then run it at 50mph for about 10-20 minutes to clear it..
9th Jan 2018 4:31pm |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
I got the yellow warning last October. Once the engine was warm, I used a little more right foot for acceleration while keeping it in lower gears (in the lakes at the time) for around 10-15 mins, that cleared it for me, just needs to get hot. |
9th Jan 2018 5:45pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
I too do lots of short runs. Stan's advice worked for me. Just let the engine get up to temperature then go for your 50mph+ drive. Holding the car in lower gears to get the revs up - as some people advised me - doesn't need to be done. What do I put here then? |
9th Jan 2018 5:50pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1233 |
tI found in my freelander than ragging the nuts off the engine to clear the DPF was a waste of time. As mentioned above, driving normally between 50 and 70-mph seemed to be far more effective at clearing it.
9th Jan 2018 6:23pm |
GavinBell Member Since: 10 Sep 2017 Location: Phnom Penh Posts: 88 |
The dreaded warning came on for the first time in my ownership.....
9th Jan 2018 6:39pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
Is DPF regeneration silent ? |
9th Jan 2018 9:11pm |
if it does make a sound you wouldnt hear it over the engine/road noise.... ... - .- -.
9th Jan 2018 9:16pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Thank you for the replies, very helpful |
10th Jan 2018 1:14am |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 |
I didn't think the TDV8 3.6 had a DPF, I thought it was only introduced in the 4.4? |
10th Jan 2018 3:56pm |
it was optional,
10th Jan 2018 4:19pm |
