Home > Maintenance & Mods (L322) > Sid step removal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34911 |
if the steps are integrated with the front flaps then you are correct there will be two holes left in the lower panel ..these panels can sometimes be found on ebay... ... - .- -.
10th Jan 2018 4:02pm |
MikeT Member Since: 19 May 2014 Location: Moscow Posts: 87 |
Ok cheers Stan |
11th Jan 2018 7:42am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Two fat bolts on the bottom of each and four off the higher brackets of each plus the wings...
11th Jan 2018 4:49pm |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 64 |
This is one time when you may be glad someone fitted aftermarket side steps! When I bought my car the brackets for the steps were very rusty so I decided to remove them on safety grounds. They fed into the front mudflaps as per the OEM ones (which I thought they were) so I was wondering what to do about the holes in the wings but - result! - when I took them off the mudflaps only had fittings on the inside of the arches... so no unsightly holes.
12th Jan 2018 7:00pm |
