Home > Maintenance & Mods (L322) > 2011 range rover 4.4 TDV8 Vacuum oil change.
headless21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi, I am just wondering where you vacuum the engine oil from (where to insert the tube from the vacuum pump), I have always used the sump plug before. Is there a specific tube to use or do you use the engine oil filling location? I can't seem to find any info on changing the engine oil via a vacuum pump on the 4.4 tdv8.
Thanks Thumbs Up Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
2003 Range Rover Vogue SE
1997 Range Rover DSE
1990 Range Rover Vogue SE
1985 Range Rover 2 Door
1979 Land Rover Series 3
Post #465183 19th Jan 2018 10:55pm
The dipstick tube has a black twist off lid... To the left of the engine (where the dipstick would be on a 3.6)
Post #465185 19th Jan 2018 10:59pm
nino_nino
here is the pic. to help you
Post #465187 19th Jan 2018 11:11pm
headless21
That's brilliant, thanks for the quick response I really appreciate it. Thumbs Up Bow down Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
Post #465188 19th Jan 2018 11:15pm
Rambles
Not seeing what you mean in the first piccie
Post #465242 20th Jan 2018 4:09pm
