Home > Maintenance & Mods (L322) > Burning oil smell |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Sounds like the common oil cooler seals , or the pipe at the back of the engine leaking that Craig mentioned on here a while back. |
20th Jan 2018 6:00pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
I agree with Paul.
20th Jan 2018 6:15pm |
Bluealpina Member Since: 13 Aug 2017 Location: Northants Posts: 30 |
Are they the ones that allow oil to mix in the water as ive just paid to have that job done before i left the uk
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
It’s the oil cooler itself that cracks I believe. Just doing seals won’t be enough....the oil rings on the pipes that can also be an issue shouldn’t let that much oil out......
20th Jan 2018 6:34pm |
Thanks
20th Jan 2018 7:11pm |
If you have just had the cooler seals done then I would be looking at the 2 orings at the back of the engine. Easy fix for next to no money. Craig has a thread on it. The orings are readily available on the net and upgraded viton rings are recommended!
20th Jan 2018 7:15pm |
Thanks will sort when i get back |
20th Jan 2018 10:20pm |
