Home > Technical (L322) > 2003 L322 TD6 access to Exhaust manifold and turbo? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I have been considering the same job myself, you can either take all the inlet manifold off and I think possibly cam cover - there is a guy on YouTube that has done it that way but if you want to remove the turbo the easier way I have read about is to remove the 3 rubber bungs in the bottom of the air filter housing which uncovers the turbo bolts , remove the exhaust and take the turbo out from below which is how it says to do it in Rave.
27th Jan 2018 12:37am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
I found this and he says it can be done without all the work in the long winded youtube tutorial.
27th Jan 2018 9:24am |
I have read that as well, the procedure is in rave which is the removal from below method, do you have rave from the Wiki? |
27th Jan 2018 9:39am |
I have a copy of that rave. I do not want to remove the turbo, i want to check my manifold bolts , check the turbo hoes etc, If I can gain access from the top it would make life easier. |
27th Jan 2018 4:38pm |
That's pretty much the procedure you have seen on youtube then i believe with the injectors out and camshaft cover etc. If you look in rave under TD6 exhaust manifold gasket that will tell you where you need to go as the bottom of the air cleaner box is part of the camcover looking at it.
27th Jan 2018 5:36pm |
What a sod of a job having to remove all that just to remove the bottom cover of the air filter compartment! so to check exhaust manifold bolts etc, that you need to strip the top part of the engine GRRRRRRR! |
28th Jan 2018 11:06pm |
I know, i wanted to check the turbo actuator which is right below it but unless you can feel your way up from underneath then its got to come out from what i can see. |
29th Jan 2018 12:37am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
Harlie on AULRO recons he can get the Turbo off in 20 mins, maybe do a search on AULRO. Please keep us up to date on the process 2007 TDV8 VSE
30th Jan 2018 12:51pm |
I think if you have done it before and the covers were off underneath and above with the air filter out and the bolts weren't seized, then i don't think it would take long but 20 minutes i think would be pushing it
30th Jan 2018 7:52pm |
Took the turbo off the TD6 on Sunday and it was surprisingly easy although it still took me 2 hours which included getting all 4 wheels up onto sleepers which meant using a small step ladder to do the engine bits.
13th Feb 2018 12:40am |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 |
I used the method, from above, and it was terrible .... |
20th Feb 2018 4:01pm |
What was terrible, I couldn’t believe how easy it was ?
20th Feb 2018 8:08pm |
I chose the longest route, remove the whole top, and I can tell you that it was not easy, since the car has 300,000 km I took the opportunity to take a look at all the other components.
21st Feb 2018 9:29am |
ok, yes i have seen the youtube video of that and it looks like a massive job. The landrover method is to remove the turbo from underneath but if you wanted to check your inlet manifold and other components then it makes sense to do it the top off way but sounds like it is a pain
21st Feb 2018 7:00pm |
