Home > Wheels & Tyres > Discovery 2 wheels to L322? |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
I'd be worried about the load rating of the wheels - The L322 is a fair bit heavier than a Disco 2.
26th Jan 2018 4:37pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Edited: D2 wheels are not straight swaps, no. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
26th Jan 2018 4:53pm |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
Depending on the wheel you might need different nuts , I just swapped some 18" that were available on the disco , they had black nuts but they didn't fit the 19" wheels which needed the chrome nuts |
26th Jan 2018 6:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
OP was asking about Discovery 2....
26th Jan 2018 6:46pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2303 |
No, the D2 centering hub is smaller diameter. |
26th Jan 2018 9:02pm |
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 |
GraemeS
26th Jan 2018 10:36pm |
As above... 322 wheels will fit a D2 using a spigot ring but D2 wheels won’t fit over the hub of a 322 unless the centres are milled out on a lathe... |
26th Jan 2018 10:41pm |
Gunning Member Since: 28 Sep 2016 Location: Cornwall Posts: 233 |
I was told a tdv8 couldn’t have anything less than a 19” wheel due to the calliper clearance on the front 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
26th Jan 2018 11:06pm |
Some compomotive 18” alloys will fit a TDV8 but most 18” alloys won’t sir |
26th Jan 2018 11:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
^ like these,
26th Jan 2018 11:19pm |
^ them are 19” D4 wheels Stan |
26th Jan 2018 11:42pm |
Ask me how i know
26th Jan 2018 11:43pm |
17'' BB6 performance fit td6s if that helps
27th Jan 2018 1:30am |
