Home > Technical (L322) > Annoying hissing under load |
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 |
Still sounds like an air hose. Also check the matrix and endcaps of the intercooler itself.
30th Jan 2018 8:36pm |
Mark07Tdv8 Member Since: 30 Jan 2018 Location: West Yorkshire Posts: 15 |
Thanks for the speedy response. New to the forum and really appreciate it.
30th Jan 2018 8:55pm |
look for damage. Failed welds, punctured matrix etc. The Inter-cooler is basically the same idea as your engine radiator, so look for the sort of damage that would let out water, and you can bet it'll let out air. Make sure the hoses are on square, not half on/half off.
30th Jan 2018 9:00pm |
Thanks for the reply again.
30th Jan 2018 9:05pm |
The best idea is to wipe off any oil you find, and drive it for a little bit to see if it comes back. I would expect any garage worth the money you pay them to clean hoses and other components if they're going to re-use them, so i'd say you've found a very likely suspect there. |
30th Jan 2018 9:07pm |
Thanks for that, I will check them in the morning. It must be something that they have removed to do the alternator as the noise wasn’t there before. Is there any other pipes at the drivers side lower down that could be the issue? Sorry for all the questions never looked any lower down than the top cover as I’m a builder |
30th Jan 2018 9:33pm |
Sorry chap, i'm not really much use on specifics, I've only had mine since November. I do believe the TDV8 has a surprisingly large number of hoses however, so rule nothing out in your pursuit of the source.
30th Jan 2018 9:38pm |
Never thought of them causing damage to something. Seen as though they had already put a screwdriver through the turbo air inlet pipe this is probably highly likely. Is there any way of testing the intercooler? Are they easy to change? Thanks for all your help |
30th Jan 2018 10:03pm |
Sorry mate, you're rapidly exceeding my knowledge, I can only hope one of the more experienced forum members chimes in in that regard. I shouldn't think its too difficult to change, but i'm willing to bet it's buried somewhere awful to get to, likely best accessed from underneath the front bumper (which would mean removal of the undertray).
30th Jan 2018 10:09pm |
30th Jan 2018 10:11pm |
No problem Mark, glad to have been of some sort of use. Hope you get to the bottom of it, I'd be in constant anguish if mine was suffering like that so totally get the desire to make her right. |
30th Jan 2018 10:13pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
Have you removed the plastic cover over the engine, so that you can see the condition of the other "boost" hoses.
30th Jan 2018 10:36pm |
Hiya, thanks for your reply.
30th Jan 2018 11:34pm |
Mark,
31st Jan 2018 12:08am |
