Home > Maintenance & Mods (L322) > Genuine Exterior design bumper question |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Mine are genuine... Current stable:
10th Feb 2018 11:19pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
cool, i thought for a minute you had the plastic ones |
10th Feb 2018 11:23pm |
I can’t work this out one has a gap from the side the other doesn’t and ininstalled identically - I feel a hidden cable tie coming in... also even the decent one doesn’t look great from the side.. I am I missing a trick here?
11th Feb 2018 9:51pm |
They are definitely wrong but not having fitted them to mine i can't help. send them to me and i'll fit them to mine and then you wont have a problem anymore . |
11th Feb 2018 10:46pm |
Haha maybe one of the other guys could send a side shot? Thanks Current stable:
12th Feb 2018 7:45am |
Nino already did and you can see they are fitting flush with the bumper |
12th Feb 2018 8:49am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
I remember they are on a bracket and is it pressed up enough it can only be the black bracket not right surely? As you can see zooming in they should be really flush
12th Feb 2018 12:36pm |
any chance of a low down close up shot either side? Current stable:
12th Feb 2018 5:10pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3682 |
From the side it looks like they are about to drop off, are all the brackets in place ? Is the bumper designed / meant to fit this Model Year - something doesn't look quite right - perhaps have a look under a later vehicle to see if all the mounting brackets are the same ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
12th Feb 2018 7:16pm |
I only have the front three bolts in should I have some at the back? Current stable:
12th Feb 2018 8:32pm |
No idea, have you checked Topix or the LR website for fitting instructions - there is a whole section dedicated to accesory fitment - may or cover older vehicles tbohgh but worth a look - didn't yours come with instructions ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
12th Feb 2018 10:23pm |
No got it used... Current stable:
12th Feb 2018 10:27pm |
