Home > In Car Electronics (L322) > EBAY DVD Changer - "NO DISC" error message
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Got disappointed yesterday when I installed a DVD player from a UK seller (region 2 lilke in Norway) and it did not work.
It scans through the magazine and even detects that there are 3 DVDs in there (see picture) but still I get an error message saying NO DISC.
I have included pictures of the part nos for both DVD players, the one from EBAY is the one with a rip in the sticker. Sorry about the picture being upside down...
Do I have a player from the wrong region? And how can you tell from the player? The seller states that it did work when he removed it.
Thankful for any input!
[/img] 2006 Supercharged
Post #467541 6th Feb 2018 1:48pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
The information on the stickers looks to be the same, have you tried using different discs and also putting discs in different slots in the cartridge?
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #467557 6th Feb 2018 3:23pm
Ian928
As you can see on the picture, there are DVDs in slot 1, 3 and 6. I have not tried the other slots. 2006 Supercharged
Post #467560 6th Feb 2018 3:32pm
zarnd
Are they genuine or copied DVD's? I can't remember, but think I have had similar when the region was different to the player in the past. I might see if I can try and put an incorrect region disc into mine and see what it does to compare.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #467563 6th Feb 2018 3:53pm
Ian928
1 and 3 are genuine and was working on a portable player I have been keeping in the car. Number 6 is a cleaning disc.
The seller is a nice guy, I can try to make it work and if not I can return it. I would rather make it work...
I would be very happy if someone could confirm if this problem indeed is Region related. I have my old player that should be the correct region, maybe I can combine parts and make it work. 2006 Supercharged
Post #467630 7th Feb 2018 8:22am
Bob
England 2004 Range Rover Vogue 4.4 V8 Giverny Green
Hi just had my L322 for a couple of weeks and had the same fault
I think the mechanism gets hot and the silicon grease dries out in the auto changer
I removed the cd cassette and squirted wd40 silicon on the mechanism (not the oil based lube)
This cured my changer and it now works perfectly
Post #467721 7th Feb 2018 11:50pm
Ian928
That is very interesting! We did in fact try the same but were not as lucky as you. We dismantled the old unit and lubricated it with silicone spray so if we get permission to open the new one from the seller we will try to do that.
You are sure you received the exact same message? 2006 Supercharged
Post #467739 8th Feb 2018 10:59am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Was issue sorted out. I ask as I came across this
https://www.aliexpress.com/item/Clarion-6-...0.0.dxS2vA
Thought may help Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #469768 23rd Feb 2018 11:48am
Ian928
Thank you, very interesting! This is the CD player though... 2006 Supercharged
Post #469940 24th Feb 2018 10:09pm
Ian928
Ok, now we have tried a third player! This did play some DVD but not all. We sprayed it with silicone and probably got something on the lens. We tried a dry clening disc but that did nothing. We dismantled and cleaned with q-tios with water and dried it off with dry q-tips. We are now back to where it will recognize some DVDs but most of them will show only "NO DISC".
Are there any tips about cleaning the lens? Or other tips for that matter. I am getting a bit tired of this now... 2006 Supercharged
Post #470291 27th Feb 2018 8:52pm
nino_nino
Ian, use Isopropil (rubbing) alcohol 96% to clean lens
Post #470346 28th Feb 2018 10:13am
Ian928
Ok, an update. We cleaned the lens with CRC electronic cleaner and afterwards it plates no DVDs. The day after i again plates the same DVDs it had played before cleaning.
Got tired an placed it aside and ordered acleaning disc with a dedicated cleaning liquid. Last week I connected it to try and clean with the new cleaning dsc, and to my surprise it played all DVDs upon startup. I have used it a week now and it is perfect, the children love it and therefore also do I...
I can think of 2 possible explanations for this behaviour:
1 The player dont like Norwegian winter. It was way below zero when we tested it first.
2 i have read that there are 2 lasers going through the same lens in this player, I guess this is achieved by prisms of some sort. Maybe cleaner got stuck innbetween lens/PRISM/laser and evaporated over time? 2006 Supercharged
Post #477550 4th May 2018 8:58pm
