Home > Technical (L405) > Tailgate out of alignment, dealer problem
Bluestu33
United Kingdom 2014 Range Rover Vogue SE SDV8 Loire Blue
Hi all,
I have a 2014 L405 and in the past few weeks the boot has not been opening and closing correctly.
When it does open, the top,part opens and the bottom doesn't. When pressing the button for the bottom part, quite a loud bang happens and then it opens.
The boot will not close automatically, so I have to manually shut it, which it doesn't fully close.
I had it into the garage today and they said that it is out of alignment, probably caused by a rear end shunt and as such I will have to pay to have it fixed.
I have had the car for a year and a half and I have never been in an accident. I bought the car from a main dealer in York.
Surely a rear end shunt would cause more damage than putting the boot out of alignment???
I am going to dispute this with the garage when they give me a quote, but any suggestions on how I should handle this would be welcome.
Thanks in advance!
Stuart
Post #467591 6th Feb 2018 8:11pm
AMD
What a load of b Censored ks. I have a 2014 and at the weekend the lower shelf only opened half way and would not budge any further down although there was slack in the wires. Raised it a few times and then it lowered properly. I’ve never had a shunt...it’s just the many intermittent faults on a Land Rover which a main dealer can never find a solution for! Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #467593 6th Feb 2018 8:53pm
pld118
Try this:
TOPIx reveals:
17.11.2016 technical bulletin
LTB00926v2 - Tailgate Incorrectly Aligned/Fouls D Pillar Exterior Trims
Tailgate Close Is Inoperative When Using The Smart Key
A customer may report a concern that the tailgate intermittently will not close when the tailgate close button is pressed using the smart key.
Global reference: LTB00809
Post #467611 6th Feb 2018 10:35pm
Bluestu33
Thank you! That is really helpful.
I'll be ready when they say "it's not covered by warranty"
Post #467622 6th Feb 2018 11:30pm
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Apologies for very late response to this but I had same issue with 2014 with < 15k miles on it late last year. Apparently the hinges were worn and weren't covered by the warranty. The dealer I bought mine from eventually agreed to cover it. How'd you get on?
Post #477279 1st May 2018 2:59pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Good luck with it, but a technical bulletin will not mean it's covered by warranty. It's there to help the dealers and techs to solve common problems quicker without contacting them
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #477341 2nd May 2018 11:14am
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
I had a tailgate opening/closing problem as described above on my 2014 VSE and Hunters in Guildford adjusted it free of charge under my warranty a couple of weeks ago.....
Post #477997 11th May 2018 5:25am
Bluestu33
I had an absolute mare with getting this fixed. My local dealer said to me that it has been in an accident and that I would have to pay.
I contacted the CEO by email and got a very helpful call the following day, however it took a number of attempts to get it fixed.
It amazes me how shocking the level of service I have received from multiple main dealers, I am very tempted to get rid of the car.
Post #479491 27th May 2018 8:38pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Did anyone get to the bottom of this? Was it an alignment problem or something fixable?
Post #481906 26th Jun 2018 3:57pm
Red Maverick
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
There is a great video on you tube how to fix this problem - I would guess that the pin has come off under the lower flap - it’s a ten minute fix.
Post #526236 27th Aug 2019 1:56pm
A link would be useful.......
Post #526266 27th Aug 2019 6:37pm
Red Maverick
Sorry !!
Link attached
Post #526286 27th Aug 2019 9:03pm
Thanks - useful video Thumbs Up
Unfortunately my problem is different - lower won't close - but that shows how to remove the cover, so I may have a poke around in there & see if there is anything obvious
Post #526310 28th Aug 2019 7:53am
Aspman
United Kingdom 2018 Range Rover Vogue TDV6 Balmoral Blue
Sorry to resurrect an old thread. My RR is in right now for lower tailgate issues (inconsistent opening and closing) and I've been told the same thing that the upper tailgate is out of alignment.
The car is a 09/18 model which I bought in August 20. I've only done about 1500 miles in the ar since then thanks to Covid. I was also told that this isn't a warranty issue but there are no signs of any damage to the car (certainly has't been bumped since I've got it). £120 to fix, which although isn't catastrophic is a pain.
Is this common? If it's not impact damage what caused it?
Post #587891 18th Mar 2021 3:36pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
The upper tailgate is made of plastic. It goes out of alignment by itself! After a little over a year, mine did not soft close anymore. My dealer wouldn't bother... This thread details some adjusting procedures, if you are tempted to do it yourself:
https://www.fullfatrr.com/forum/topic57442-15.html 2019 Vogue P400e
Post #587899 18th Mar 2021 3:53pm
