Home > Technical (L405) > heating problems RR Vogue SE 4.4TDV8 2013 |
RRVSE-2 Member Since: 06 Jun 2015 Location: Kent Posts: 41 |
Any chance this could be the culprit !
7th Feb 2018 9:32pm |
Skennedy72 Member Since: 07 Feb 2018 Location: hillsborough Posts: 3 |
Thanks will get my ex LR service guy to check and report back |
7th Feb 2018 9:49pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
That valve set is located on the inner nearside wing and controls temp left and right it is after the heater matrix in the system - the fact that the temperature varies means it is probably working - when you say it is normal are you talking about the temperature or the speed of the blower ? |
7th Feb 2018 10:09pm |
heater fans normal will go from low to high on demand
7th Feb 2018 10:12pm |
