Home > Technical (L322) > Climate seat fault code ? |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
On the face of it, it sounds like the seat back unit thermistor has given up. But if that was the case, then the cooling cycle would still work.
8th Feb 2018 10:56pm |
philip600 Member Since: 04 Feb 2018 Location: North East Posts: 36 |
Hi, I think the issue is something that would stop both working unless they both have the same fault, I've read the posts on the link you've copied & will have a look into it this weekend but I just wondered if anyone knew if these codes actually point to the fault or are they just a general 'the seat isn't working' code which seems a bit pointless as you can tell when they aren't working ?
9th Feb 2018 4:24pm |
Hi, just an update on this issue. I've had the RR into a local LR specialist who diagnosed both seat back modules were faulty. He's replaced them & I now have working heated or cooled seats
14th Mar 2018 8:55pm |
