Home > In Car Electronics (L322) > 2011 TV - no channels showing? |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
Is it set up for UK? I'll go out to mine in a minute and check where but somewhere in the settings you have to tell it which country you want the tv set up for - its perhaps been reset after a battery change and needs set up properly. Current Fleet:-
10th Feb 2018 1:09pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
Thanks Nick.
10th Feb 2018 1:23pm |
I'd check the digital aerial to be honest - broken wire or loose connection - cheapest fix first! Current Fleet:-
10th Feb 2018 5:21pm |
Thanks, if it ever stops raining tomorrow I'll try to take the tuner unit out of the boot and check the antenna connection.
10th Feb 2018 6:14pm |
The small black wire multiplug connector had almost pulled out of one of the antenna amplifiers in the right side boot compartment and was slightly broken, so I fixed that this morning. Will leave the TV on for a while on the way home later today to see if that helps it find anything.
11th Feb 2018 10:41am |
Tonight I tried disconnecting the power plug from the back of the tuner module to hard reset it if nothing else, and then the DualView screen wouldn't turn on at all - just sat there flashing it's orange light at me on the left hand control.
12th Feb 2018 10:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
its possible that the previous owner has taken out the digital tuner and replaced it with the old analogue one..
13th Feb 2018 9:33am |
Thanks Stan. Yes, definitely a digital one in there, says something like "PAG Digital Tuner" on it, and I'm sure I checked the number at the weekend and it was correct. Will double check that again tonight though, in case it's one of these Japanese market ones that has been fitted that I've read about, with a subtly different number that I missed!
13th Feb 2018 11:14am |
sorry - I keep forgetting to go and see if I can change the settings on mine - will try tonight and let you know. Current Fleet:-
13th Feb 2018 1:32pm |
i can confirm that you can change countries and broadcast bands in the settings... ... - .- -.
13th Feb 2018 2:00pm |
Perfect, thanks Stan/Nick - something is clearly wrong with my setup somewhere then - it won't let me select any options for the TV.
13th Feb 2018 2:41pm |
its frustrating when some thing doesnt work on the FF but dont loose to much sleep as you might find you wont use the TV because of its restrictions..
13th Feb 2018 3:19pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 326 |
Getting my fix of Winter Olympics this morning when I arrived at work made having TV worthwhile !
13th Feb 2018 3:55pm |
Absolutely agreed Stan, that's why I definitely don't need to pay for someone to investigate/fix it at typical dealer rates! At the end of the day like you say it's a bit of a gimmick that likely won't get used much, if at all, for exactly the reasons you describe. But would just be nice to know it works, if I could fix it for a reasonable price myself.
13th Feb 2018 3:56pm |
