Home > Technical (L322) > Fed up with XENONS |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
I could never work out whether it was the ignitor or ballast resistor that was causing the problems. I ended up buying complete second-hand units [including balast resistor] from eBay for around £45-£55 per side which solved the problem.
10th Feb 2018 12:26pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Cheap enough
11th Feb 2018 2:07am |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 171 |
I had this randomly on either side and solved it by replacing the lighting module which works both lights.
11th Feb 2018 11:04am |
