Home > Technical (L322) > Steering Column Motors |
Gunni Member Since: 13 Jan 2018 Location: Dorset Posts: 16 |
It’s possible that there is a problem but It could be they have been turned off. I switched mine off as I didn’t fancy motor failure. You will need decent diagnostics to access the settings though.
12th Feb 2018 9:37pm |
peterweston1 Member Since: 07 Dec 2017 Location: Suffolk Posts: 8 |
Hi Jon
13th Feb 2018 9:28am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
Not sure if the foxwell is capable of doing the job.
13th Feb 2018 9:45am |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
It's worth taking the steering wheel cowl off before spending any money.
13th Feb 2018 9:47am |
Best to fill in your vehicle profile too so we know how best to help. ______________________________
13th Feb 2018 9:50am |
Thanks Simon, I will check that out. Regards |
13th Feb 2018 9:51am |
Sure, will do! Regards |
13th Feb 2018 9:52am |
Interesting, never thought of that! |
13th Feb 2018 9:53am |
No problem and best of luck sorting it out...... ______________________________
Unnecessary quote removed
13th Feb 2018 10:54am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
On a BMW era L322 its fairly common for the motors or the mechanisms to fail on these and the older these cars get the less likely they will continue to work. An new column these days is thousands. If you can hear the motors running (I assume you can't) and the column isn't moving there are fixes but if you can't hear the motors then as previously suggested, take the cowling off and check if there is power to the feeds. Current Fleet:-
13th Feb 2018 2:26pm |
Thanks Nicksaab
13th Feb 2018 2:33pm |
