Home > Maintenance & Mods (L322) > Suspension Clunk and Tie rod ends |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1223 |
All ball joints should be able to rotate / twist around the joint but I would say the movement should be stiff but smooth.
12th Feb 2018 9:36pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Re the twisting i can pretty much move them by hand which possibly means they are a bit too loose. Will jack the car up and try the 3 and 9 oclock position wobble too and maybe replace them.
13th Feb 2018 6:53am |
An update on this thread the clunk is no more once I changed inner and outer track rod / tie rod ends. The inners werent gone but there would be no way to get the outters off easily so did both! Seemed like the loose ball joints were hitting the brake disk shield causing the loud noise. Current 2007 TDV8 Vogue Buckingham Blue |
19th Apr 2018 6:15pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2212 |
Check your rear bushes sounds daft but if failing they can give you a clunk that sounds as if it is coming from the front |
19th Apr 2018 8:58pm |
Thanks if any clunking returns i will start there as the front all seems solid now. For now though its all good Current 2007 TDV8 Vogue Buckingham Blue |
20th Apr 2018 5:49am |
