Home > General > 4.2 supercharged advice |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
Are you specifically looking for a S/C version? If not, for 16k you should be able to get into a good spec Vogue SE 2010/2011 4.4 diesel if you're prepared to be patient and look around for the one that suits you. 2017 4.4 SDV8 Autobiography
15th Feb 2018 11:27pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2212 |
Just a bit more info the 4.2 is pretty much bombproof mine is on 155k and compression is still right up there and as far as I know there are no issues with it as an engine.
16th Feb 2018 6:08pm |
