Home > Maintenance & Mods (L322) > Fog lights Ballast? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
instead of the resistor you could wire up a small bulb or if you have an iidtool you can switch off hot& cold monitoring.. ... - .- -.
17th Feb 2018 5:05pm |
See here:
17th Feb 2018 5:10pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
As always, yous are stars. Thanks so much.
17th Feb 2018 5:45pm |
Can't switch off cold monitoring on '02-'05 models .
17th Feb 2018 6:24pm |
olliecat2 Member Since: 30 Jan 2018 Location: FLINTSHIRE Posts: 13 |
I,m not sure why but for the last week I have been getting the error message check front fog lights . I have checked and they work. Perhaps the cars turning psychic |
20th Feb 2018 6:27pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I occasionally get either a 'Check Front Fog Light' or 'Check Dip Beam Light' when I turn the lights on of a morning. It only happens when it's really cold (e.g. -2C this morning) so I think it's just the cold weather affecting the resistance of the wiring, as both the Fogs and Main Lights work perfectly.
21st Feb 2018 2:15pm |
Mines now every time I start or turn off. As say, I swapped ballast and the fault (according to icarsoft) swapped with it. Just waiting on replacement to arrive and will update! Accept, some days your the pigeon, some days your the statue! |
21st Feb 2018 4:56pm |
