Home > Technical (L322) > Rear side mirror |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 137 |
As you may know here in Portugal is LHD.
17th Feb 2018 8:06pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
Have you a user manual? Im sure one of the MY’s you could set the mirror to how you wanted it... Move the selector to the pass side and select reverse, then set the mirror glass to where you want it and when you take the car back out of reverse the mirror glass reverts back to set point...
17th Feb 2018 8:14pm |
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 |
My passenger side mirror dips no problem but it rarely goes back to its driving position which does my head in. |
17th Feb 2018 9:45pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
What is supposed to happen is this.
17th Feb 2018 10:32pm |
I keep my mirror selector set to the passenger side. It definitely dips & sometimes moves back to it's normal position but 9 times out of 10 it doesn't. My fatty is LHD but I doubt this would make a difference but I'll try keeping it set to the drivers side for a while to see what happens. |
17th Feb 2018 11:49pm |
So today I used the Fatty & remembered to set the mirror selector switch to the drivers side & wow it now works as it should. I never would've twigged this as no one but me ever drives it & I kept it set to the passenger side so I could re adjust it after each time it dipped but didn't return. So a big thankyou Berkshirelad for your explanation. |
18th Feb 2018 11:19pm |
