Home > Technical (L322) > 2011 4.4 TDV8 - Restricted Performance |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
seem to remember another member getting that message. Faulty sensor I think. Do a search 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
18th Feb 2018 8:51pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2304 |
The faulty EGR sensor fault doesn't cause restricted performance on mine. I replaced the sensor because I spotted the fault code but the fault code soon returned so I ignore it. |
18th Feb 2018 9:44pm |
Would be looking for a boost leak somewhere. Possibly a split in one of the 4 shoe hoses to the plastic plenum or in the plastic intake plenum itself. There is nothing that can't be fixed with a hammer😜😜
18th Feb 2018 11:14pm |
The first code is for a sensor in the NS exhaust manifold, this tells the ECU its running lean or rich this then increases or decreases the fuel trim... If it fails in one position then it will over fuel the car and it makes the exhaust STINK like a 1970s ice cream van!
19th Feb 2018 12:14am |
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 |
Thank you, so it seems the EGR code would not cause the restricted performance. LR say it is bear being a ghost code. Would it be the water code setting it off then? |
19th Feb 2018 8:41am |
19th Feb 2018 10:16am |
Thank you Craig |
19th Feb 2018 11:25am |
JAS York looked at it and fixed it for me today. It needed a new fuel filter housing and sensor, and a new exhaust gas temperature sensor. |
28th Feb 2018 9:25pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Do you mind if I ask how much it cost for the repairs. I also have the same faults. Water in fuel circuit comes up every so often throwing the restricted performance warning (although it doesn't seem like performance is restricted). The EGR sensor is persistent though and i cant clear that with my IDTTool as it comes straight back on. 2011 RR Autobiography 4.4 TDV8 |
7th Mar 2018 6:40pm |
I have sent you a pm dirtymonkey |
7th Mar 2018 9:58pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Otley Dominic,
7th Mar 2018 10:28pm |
Received. Thanks for the info. Although not local, they are not a million miles away 2011 RR Autobiography 4.4 TDV8 |
7th Mar 2018 10:45pm |
It takes me 1.5 hour drive to get there. But they have a loan car and a coffee shop nearby I worked from for the day while they had mine. |
7th Mar 2018 11:26pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Mike, can you post one of yours beautiful PDF's showing where the sensor is, I'll like to go at it.
8th Mar 2018 8:55am |
