Home > Maintenance & Mods (L322) > Front/Rear Diff & Transfer Case Oil Change |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Brilliant instructions for both courtesy of EmiratesA380 here:
18th Feb 2018 10:34pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
Thanks Greg.I had seen these but didn’t know if the recommendation was to change both filler and drain plugs, or just drain only. Also I guess I need to replace both copper washers on the fill and drain of the transfer case? Chris |
18th Feb 2018 10:49pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
Why would one replace the plugs?
19th Feb 2018 1:43am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
I did mine and didnt replace any plugs and have had no issues since and cant remeber seeing any washers but msy be wrong. Current 2007 TDV8 Vogue Buckingham Blue |
19th Feb 2018 9:47am |
Are there any specific tools you'd need for the diffs and the TC?
19th Feb 2018 10:03am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6653 |
I did mine and I don’t recall having the need for any special tools that I didn’t already have. Got - 2017 SDV8 Autobiography in Loire Blue
19th Feb 2018 10:17am |
Cant remeber exactly but i did need to get a big hex key for 1 the i then put in a half inch drive socket as that was easier than using a spanner with it. Will have a look in he tool box. Also there was a square hole in the bolt that i got out with a radiator spanner, the ones with the half inch alen and square bit you get from tool station etc. The final one cant remember but didnt need anything special other than a socket set. Current 2007 TDV8 Vogue Buckingham Blue |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
You need a 14mm Allen bit (for a socket wrench) for the diffs, and a normal 16mm (I think) hex socket for the transfer box. And a torque wrench that can be used for every plug or bolt - check that it can do quite low values. I think a 8-60 Nm torque wrench is a handy tool for working on diffs/transfer box/the gearbox.
19th Feb 2018 10:49am |
Checked my tool box and it was 14 mm hex key I got one with 14mm one side 17mm the other and used the 17mm socket set on it and worked well. Link to one like I got
19th Feb 2018 1:41pm |
