Home > Maintenance & Mods (L322) > Antifreeze, how do you check yours? |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
The car usuall requires some work yearly that requires the coolant dropped, we always refill with new at 50% so I’m confident it’s up to spec
25th Feb 2018 7:54am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3682 |
We test our vehicles with One of these :-
25th Feb 2018 8:18am |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 89 |
@Vogue I have something similar, how do you collect a sample?
25th Feb 2018 3:12pm |
Just suck a bit out of the cooling system expansion tank 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
25th Feb 2018 6:37pm |
Yep I find I have to wait till it’s warm then open the filler and the bleed screw to raise the level enough to get some out, then when finished I have to bleed the air out again, just wondered if there was a better way |
25th Feb 2018 7:42pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Andy, ad piece of plastic/rubber tubing to turkey baster,
26th Feb 2018 9:24am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3659 |
You have taught me yet another gem Nino.
26th Feb 2018 10:55am |
Mike, I'v learned that on this forum and tested It when I had my expansion tank off for cleaning. filling tank with just water resulted in a warning, adding antifreeze OK .
26th Feb 2018 1:00pm |
QED. G reg 2.5VM Vogue Portofino red 1991- 1999
26th Feb 2018 1:32pm |
