Home > General > [SOLVED!] "PARK" / "P" not holding :(
Page 1 of 3 123>
Pulled up to a set of traffic lights a couple of days ago, on a slight incline, and put gearbox into PARK as usual, but then clunk clunk clunk it started moving forward! Just stopped in time before hitting car in front Smile Also happening if on an upward incline. Doesn't happen everytime, but even on the level it will try to pull forward.
Is this an adjustment thing or a more expensive problem. Gearbox only 2 years old having replaced it (LR) after it seized up.
All help and advice appreciated.
(It was all going so well!)
Had hoped solved but still not PARKING properly! Very Happy
http://www.fullfatrr.com/forum/post69915.html#69915 (see Gary's post about the gear lever selector cable)
Now is solved see last post in thread .
Post #48835 4th Feb 2011 7:29pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
I think you're pretty much F*** Censored Censored Censored
Post #48836 4th Feb 2011 7:36pm
why? ... - .- -.
Post #48838 4th Feb 2011 7:40pm
Emperor Mong
Are the other aspects of the gearbox fine? Does it drive ok other than creeping forward in Park?
I'm not surprised of the clunks if the car is moving forward in P as there is a bloody great ratchet type affair to stop it moving.
Post #48842 4th Feb 2011 7:53pm
dan_uk_1984
Your park pin has failed. This is generally due to people using park rather than the HB. Happens a lot on big heavy cars.
When you stop on a hill you should apply the HB and let that take the slack, then and only then select park as is documented in the handbook.
AFAIK it cant be repaired in situ.
Post #48851 4th Feb 2011 8:24pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
i put it N and sit on the foot brake, back to drive when ready to go.
Sorry about the news joe90.. 2004 black Vogue TD6
Post #48862 4th Feb 2011 10:26pm
VMPP
There's this video of a LRE day, where the instructor point that out.
He even gives it a feeling of procedure... brake, neutral, handbrake, release brake, brake, park, release brake. Uff....
Post #48903 5th Feb 2011 1:21am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I don't know about the creeping forward but the poor guy in the car behind must have heart failure as the reversing lights come on just as you are about to pull away Rolling with laughter I've always been told stop, EPB on (ahem, isn't that why it's calls a PARKING brake) and then into N. BTW I also get really p Censored d off sat atbtraffic lights behind somebody stopped in front holding the car on the footbrake, especially at night on a wet night. Also I recall reading somewhere years ago that officially if you stop and don't apply the hand brake/EPB then your are not actually stopped! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #48909 5th Feb 2011 6:49am
in all the auto's i've had i have always left the car in drive with the footbrake on, except occasionally with the RR the transfer box noise? gets a bit loud because of the 20'' wheels on the car , then i just stick it in neutral. ... - .- -.
Post #48928 5th Feb 2011 10:53am
So would this have been fitted new as a part of the new gearbox going in - should it have been? Or integral part of gearbox itself? .
Post #49009 5th Feb 2011 8:02pm
dan_uk_1984
It's part of the output shaft - so internal.
It sounds as if your pin is bent because it latches sometimes - this usually happens if the car is parked on a steep slope and held with park - or P is engaged before being stopped.
Post #49014 5th Feb 2011 8:22pm
It's 27 minutes in if you don't want to watch all the way through
No wonder people sit in Drive with foot on the brake Neutral .
Post #49072 5th Feb 2011 11:35pm
Thought I would give an update on this. Haven't been to the stealer yet, but the problem is getting worse. I believe it is all about the gearstick not locating correctly rather than the park pin. it is becoming more difficult to select a gear position, and on occasion it will not stay in Drive, just bounces out into Neutral. Also will not locate properly in Park; when I come to start up the car it will not start so have to go into Neutral then start the car.
Tonight on the way home, in traffic, I put it in Neutral and handbrake on, then went to move off so put into Drive but it wouldn't go in, just bounced out again. So pushed the stick over into Manual and drove on.
First time really had a go at Manual - its quite forgiving, will kick down if you are going to slowly for a gear or if you accelerate in a high gear from low speed, but gives you that manual box braking experience if you whack it down a gear when slowing. Fun.
So feeling happier its not the park pin Rolling Eyes but sadder that there seems to be a real problem with the gearstick connections Big Cry .
Post #64233 16th May 2011 11:15pm
SteveMFr
Site Sponsor
Which you shouldn't, because the gearbox won't need to be removed to have the problem rectified (if the selector/adjustment really is the problem) = much cheaper for you.
I wouldn't procrastinate, because you'll likely end up doing internal gearbox damage if the adjustment is that far off.
EDIT: Wow- just looked back at the dates and noticed you started this thread in Feb. Joe, don't be foolish. Have it looked at before you end up needing to spring for a gearbox. Do you run around for months on end with decaying teeth in your mouth so you can get dentures rather than fillings? Shocked
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #64240 17th May 2011 6:09am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
i'm the same - leave in drive and use the foot brake Smile
Post #64250 17th May 2011 9:43am
Page 1 of 3 123>
