Home > Technical (L322) > Restricted Performance - Fault Clearance?
Zim
Hi guys,
I have a Restricted Performance issue on a 3.6 2010 Vogue SE.
I will check out and swap the top intercooler hoses for starters - then see if that has worked. The question I have is do any fault codes need to be cleared? I don't have an IID Tool.
Any help / guidance will be appreciated.
Post #471254 5th Mar 2018 10:17pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
When my hoses split I didn’t get restricted performance, just a whistle noise.
Maybe I caught it early.
In my experience it’s best to get the codes read before changing parts.
Have a look at the turbo actuators. They cycle when the ignition is switched on. I’ve had the passenger one seize causing restricted performance.
Get someone to cycle the ignition whilst you lay underneath observing the actuators 2007 3.6 TDV8
Post #471260 5th Mar 2018 10:39pm
The hoses are the most likely culprit - They can be removed in 5 mins with a screwdriver and inspected properly
I'd definitely do that as a first check - they are cheap to replace and you don't need to clear the faults.
Invest in an IID (or similar) tool if you need to - and not before IMHO
Post #471262 5th Mar 2018 10:50pm
Zim
Cheers, thanks guys.
Got the hoses on order anyway. Will take it from there once swapped out.
With the IID Tools, can they be used on other models Or are they model specific? I have TDCI Defender and a Disco 3. I'd like something that could work for all three, or at a minimum the Defender and L322.
Post #471266 5th Mar 2018 11:03pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Full vehicle coverage is here: http://www.gap-diagnostic.com/products/iidtool/
You can buy additional licences for extra vehicles for £60.
I assume you can "mix" models on the same IID Tool but you may want to confirm that with GAP.
Post #471269 5th Mar 2018 11:19pm
Zim
Thanks, I have just bought a BT IID Tool.
And even better found the source of the problem it seems. Many thanks for the input.
 MY2010 Range Rover Vogue SE
2007 Discovery 3 XS
2007 Defender 2.4 TDCI XS
Post #471479 7th Mar 2018 2:40pm
cheezels
Awesome!
A nice easy fix 2007 3.6 TDV8
Post #471499 7th Mar 2018 4:03pm
Yep dead easy Thumbs Up and quick to fix.
Should be good for a fair few years now. There is nothing that can't be fixed with a hammer😜😜
Post #471523 7th Mar 2018 7:07pm
