Home > Maintenance & Mods (L322) > Who wants to play "Identify the hose" game Thursda
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi guys
2004 TD6
Not being lazy, but cant clamber about too much in engine bay at moment because of bad back. Changing oil filter today the top has sheared straight off. Not an issue ill sort that later as its not leaking. Just did oil as road trip to Nottingham in a week.
Whilst i was working on it ive come across 2 hoses. The first is hanging down on the N/S.. About as thick as a pencil and looks like its wrapped itself around something at sometime and the ends all munched up.. Im guessing its the overflow from the radiator but it only has a tiny 1 or 2mm internal bore.
The other one im a bit concerned about. Ive had a slight diesel leak i havent been able to trace.. Could this be anything to do with it? I know there are breathers and things, but the "unconnected" end seems quite clean. As if its been attached recently.. Also the connector is barbed as if it should have a hose connected.
It doesnt suck or blow when running.
Pics taken standing from front of bonnet. Pipe runs from front of engine and up the N/S around "Broken" oil filter!
Thanks in advance
Tel
 Accept, some days your the pigeon, some days your the statue!
Post #471666 8th Mar 2018 4:11pm
holidaychicken
i'll have a TD6 with me at the weekend if nobody had been able to help by then i'll take a look
Post #471741 8th Mar 2018 11:55pm
Boydonegood
Oh thanks so much buddy!
I’ll try get and look today too but backs gone so struggling! Lol Accept, some days your the pigeon, some days your the statue!
Post #471756 9th Mar 2018 7:56am
holidaychicken
They look like vacuum pipes at first look, i'll see what i can find when i get it to me, something EGR related ?
Post #471757 9th Mar 2018 8:09am
holidaychicken
I checked today and that pipe is held in a clip but connected to nothing, it may be a breather for something or we both have the same problem !
And this has a slight diesel leak i think which could well be the high pressure pump, there is a thread on here somewhere
Post #472040 10th Mar 2018 8:57pm
Boydonegood
Buddy you are a true gentleman. Thank you so much.
Has put my mind to rest for the Nottingham road trip (week at forest holidays cabins)
Thanks my friend.
Tel Accept, some days your the pigeon, some days your the statue!
Post #472042 10th Mar 2018 9:04pm
holidaychicken
No bother mate, i see you have two hoses in question , let me see if can find that other one - can you send me another pic or has the above answered your question?
Post #472052 10th Mar 2018 9:23pm
Boydonegood
Your a gent. I’ll grab pic in morning. It’s hanging down by the N/S steering gator. It’s about as thick as a pencil but only has about a 1-2mm internal bore.
The ends been melted over where it’s rubbed on something.
I kinda guess it could be a rad or expansion over flow. But tiny bore makes me wonder. Accept, some days your the pigeon, some days your the statue!
Post #472055 10th Mar 2018 9:44pm
