Home > Maintenance & Mods (L322) > Problems from a weak battery. |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
Is there a list of all the weird faults and symptoms a marginally weak/aging battery will cause? |
8th Mar 2018 10:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34908 |
thats so true Alan.. ... - .- -.
8th Mar 2018 11:09pm |
Well that narrows it. So if the shop battery tester reports it tested good but is showing signs of aging is that enough to warrant a new one? |
9th Mar 2018 1:08am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
Abso”bloody”lutely sir...
9th Mar 2018 2:33am |
OK. I now feel better about spending money on something that isn't technically broken. |
9th Mar 2018 3:47am |
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 |
If I leave mine for a few days I get HDC inactive but it goes when the battery has been charged so I hooked it up to the CTEC and left it overnight , when I started it next morning I got the time showing on the display which I've never had before |
9th Mar 2018 9:55am |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
What problems or strange symptoms are you experiencing?
9th Mar 2018 11:21am |
A few weeks ago, just after fixing the air leak causing the Lambda fault code, I started with the HDC inactive with start up. Not every time but 1 out of 3 starts. Then a couple weeks ago when driving 500 mile in lots of rain I get air suspension /hdc/ABS inactive. Codes showed the air pressure valve and air pump temp when idle. Tried clearing codes but returned right away. Also iidtool tool said update failed when clearing ECUs. When checking the pump I found the pool of water. The pressure valve and electrical connector were in the water. Pump was dry. Dried it all. Was good for a week or so. Now I also have occasional turn key and no crank. Turn back to position 0 and try again and starts right away.
9th Mar 2018 5:47pm |
Forgot also the headlight ignition voltage less than 7 volts. I'm no electrical engineer. In fact in physics it was my worst labs but this looks like a problem.
10th Mar 2018 6:58am |
I was going to say have you checked the tightness of your battery terminals but if that picture shows your battery earth cable I would suggest you have found the cause of your problems. I would replace that cable before I changed the battery..
10th Mar 2018 9:15am |
Zoiks!! .
10th Mar 2018 1:19pm |
Yep, that’s broke. There is nothing that can't be fixed with a hammer😜😜
10th Mar 2018 3:27pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Nah.
10th Mar 2018 3:48pm |
The break was on the underside as you look down on it. I didn't notice it a couple months ago when I put the negative cut off so the satnav would drain it. Perhaps a change in angle and vibration or me being clueless.
10th Mar 2018 3:54pm |
