Home > Maintenance & Mods (L322) > lifting l322
olliecat2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
lifting l322
Quick question, is it ok to lift car on rear diff, before fitting stands,
Post #472324 12th Mar 2018 10:19pm
Strider
That is something I definately would not do, if I want to lift the rear I use a 3 tonne trolly jack fitted with a anti - damage cover on the pad and locate it as close to the roadwheel as possible on the lower suspension arm lifting each side in turn.
Im sure there are other methods that members favour but certainly I wouldnt subject the diff casing to that sort of loading. Its a expensive piece of kit to have to replace , especially if its an electronic one.
Post #472334 12th Mar 2018 11:23pm
olliecat2
Ok Thanks, its just that I spotted one being raised that way in a local garage and thought at the time that could be a bit dodgy.
Post #472406 13th Mar 2018 1:35pm
nino_nino
olliecat2, do stay away from that garage.
Post #472453 13th Mar 2018 6:02pm
j_rov
This is the correct way to lift the rear centrally (see pic)
 __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #472457 13th Mar 2018 6:16pm
