Home > Technical (L322) > HDC, Air Sus inactive + general alarm issue
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
G'day.
I own a 2005 L322 4.4 V8 and have recently had a '3 Amigo's' type issue.. HDC inactive, Air sus inactive and the central triangular alarm. The central alarm light was twitching a little before it went all out. I stopped the car and turned off the ignition, waited 30 seconds, then restarted.. no alarms. I drove for a little then used the brakes (as you do) when coming to a set of lights. The moment I touched the pedal the car behaved like it was loosing traction and engaging the ABS, or a similar feeling to using the HDC when you take your foot off the accelerator. Just a small jerky shunt of brakes (upon contact with the brake pedal) then all the alarms come up.. My thought is a wheel sensor not sending a pulse. Any one else had a similar experience and remedy..?? Thanx Matt.
Post #472997 18th Mar 2018 9:30am
Speedster356
United Kingdom 2011 Range Rover Autobiography TDV8 Alaska White
I had a 2003 TD6 And kept getting the HDC inactive message on starting. After reading about all sorts of strange electrical behaviours on this and other forums, I fitted a brand new battery and all fixed. The old battery was holding charge and starting the car OK, but just a small drop in its power seems to cause this issue. Just my experience and opinion - it could be something else for you and there are many more experienced people on here than me.
Post #473007 18th Mar 2018 10:57am
Yup, most likely an ABS sensor or reluctor ring gone bad, given your symptoms.
Sometimes the old ABS sensors are seized in place and have to be drilled out, but you may be OK given Oz weather. .
Post #473009 18th Mar 2018 11:26am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Could just be that the front tracking is way out.
I had this after a local garage bolloxed the tracking when fitting a new track rod and getting it properly set up cured the problem entirely.
Post #473070 18th Mar 2018 11:53pm
RaveRover
Hey Thanx guys for the valuable input.
I shall be looking into the whole reluctor ring / wheel sensor issue with my local Rangie shop very soon. Hope it doesn't cost me too much. Shocked
Post #473073 19th Mar 2018 4:45am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Just to add a quick check, pull the multiplug connector to the ABS ECU (front of the ABS pump block by the l/h suspension turret) and check for corrosion on the pins. Mine had this and caused similar symptoms.
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #473179 20th Mar 2018 10:08am
RaveRover
Ok, all fixed.. $2200 later.. Sad
First alarm indicated the Steering angle sensor. Replaced that. something like $500 for the part only. Problem still there.
Next alarm was the Yaw sensor. Replaced that. Something like $250. Problem still there.
Then came the real culprit.. ABS modulator. The terminals were all corroded inside the plug causing short circuiting and responsible for the other associated components to fail.
The shorting was the cause for that very weird and dangerous 'locking up' of the ABS system while driving.
Luckily my Mech fitted a good 2nd hand modulator otherwise the above price would have been more than double that. Bow down
All good now. Very Happy Very Happy
mm289, U were right.. damn multiplug. would never have thought that could be so bad.
Post #481121 17th Jun 2018 7:44am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Trouble with mechanics replacing things in hope they fix things and they don't, so you pay for all those unnessecary parts you ddin't need..
Post #481305 18th Jun 2018 9:33pm
