Home > Technical (L322) > Aircon issues |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Hi all,
14th Apr 2018 9:10pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
it most likely is -air conditioning compressor control valve .
15th Apr 2018 10:24am |
Thank you for that. I will try and get that organised, although I might just have to book it in somewhere as spare time is only an occasional friend with a 2 yr old!
15th Apr 2018 10:29am |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Hey nino
15th Apr 2018 10:37am |
You may find the solenoid for your compressor here
15th Apr 2018 10:42am |
Thanks all. Nino, would a fault in that component be picked up by a proper diagnostics device? 2010 4.4 TDV8 Vogue SE |
15th Apr 2018 2:35pm |
,kooky_guy, IIDTool is not picking any faults on mine. i've taken car to two AC specialist here and both agree it is solenoid at fault. unfortunately they are not familiar with ffrr and don't wanna do the work. so it looks like I will have to roll up the sleeve and do the work myself.
15th Apr 2018 8:00pm |
Thanks Nino. That's annoying but good to know that it probably needs a LR specialist.
16th Apr 2018 9:06am |
Hmm, just spoken to one indy who said that the only way it can't be holding pressure is if it's leaking and that the compressor won't run if there's no refrigerant in it. I would have thought that the tyre place would at least have been able to diagnose that (I thought a leak test was a legal requirement before even trying to put refrigerant in?)
16th Apr 2018 2:51pm |
Well this is a bit annoying. It's started working intermittently now. I'm wondering if it is a climate control problem as when it's working it seems to be on full cold regardless of what the temperature controls are set to.
24th Apr 2018 7:40am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1235 |
I've found that my system is quite sensitive and responsive to its solar sensor on the dash so going through cloudy and sunny sections like we get at this time of year with all the showers makes the air-con fluctuate its output temp quite a lot.
24th Apr 2018 9:24am |
Thanks for that Fisha.
24th Apr 2018 1:45pm |
Getting frustrated with this now. It's been into two garages to have the aircon fixed and neither have been able to fix it.
21st May 2018 10:16am |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 32 |
Did this ever get resolved?
3rd Aug 2018 3:53pm |
