Home > Maintenance & Mods (L322) > Bleeding Jack |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
I have a Merc Sprinter Jack but its running out of puff before it gets to a sufficient height to remove wheels - it was OK. I've ordered some Hydraulic Jack Oil to bleed it and the top it up but I just realised I don't know how to do it - can anyone help? Geoff |
20th Apr 2018 6:58pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
There's several clips on YouTube for bottle jacks in general. I don't know if any of them will be relevant. |
20th Apr 2018 10:11pm |
Cheers mate, I had a look you are right. If it confirms to "the norm" I should be OK, I've ordered the Hydraulic Oil so will give it a try next week. Geoff |
21st Apr 2018 4:44pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Broke it ?.
21st Apr 2018 8:10pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7738 |
I broke mine too put a kink in it and it leaked fluid
21st Apr 2018 8:23pm |
I removed the top cradle to fit a jacking adaptor and accidentally pushed the piston back too far, after that I couldn’t get it back together satisfactorily so it wen tin the bin...... new one on its way from the bay. There is nothing that can't be fixed with a hammer😜😜
22nd Apr 2018 12:35pm |
New jack has arrived. all shiny and new.
24th Apr 2018 10:16pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3685 |
Why on earth are you jacking up a twin axle trailer ???? Far far simpler, quicker and safer You can even make one out of a block of wood or just drive up a car ramp or even a kerb 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
24th Apr 2018 11:01pm |
Now that is a good idea!! There is nothing that can't be fixed with a hammer😜😜
25th Apr 2018 7:44pm |
Easy job but it still leaks fluid, I needed the jack to rotate the tyres because the front nearside had taken a bit of a hammering - roundabouts I think, job now done. However I still have the issue of tyre pressures I’ve got 22” wheels on an L322 I went with 33 front and 36 rear as suggested for L405, seems OK anyone have a different setup.? Geoff |
26th Apr 2018 10:20am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
use the spare when rotating the wheels.. ... - .- -.
26th Apr 2018 10:24am |
I've only got 4, spare doesn't match Geoff |
26th Apr 2018 11:03am |
I saw one of those, but seemed quite expensive and bulky for something I thought I didn't really need Whenever my trailer isn't in use, I jack it up and replace all 4 wheels with stands - so I'm kind of programmed to just jack it up. Mine still has the 'ears' on it, so relatively safe to jack a trailer axle as long as you don't drive off with it jacked up |
26th Apr 2018 11:23am |
spare doesnt have to match Geoff...
26th Apr 2018 12:27pm |
