Home > Maintenance & Mods (L322) > Disc change....
Welshdragon
Disc change....
So this afternoons little job was changing the rear brake discs.
Good thing too, as the shoes where Censored , never mind the disc on the left side !
Has anyone had any experience with discs going like this?
In all my years of landrover I've never come across this, only the usual wear marks .
New discs, shoes, and pads with new caliper on the left side as was thinking this was sticking...the right side was done a while ago.
Thanks to advanced factors for a very speedy delivery. Thumbs Up
 If it dont work.......burn it!
Post #476440 21st Apr 2018 10:18pm
Pawl
The disc surface is typical of a very siezed calliper & maybe the handbrake hasn't been used for a while - lol.
One of the penalties of an auto - it's too easy not to use the handbrake & not realise how bad it's got. Paul,
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Post #476447 21st Apr 2018 11:57pm
Welshdragon
Not wrong there. Thumbs Up
Hand brake on the RR is shockingly rubbish, not like the good old classic, defender set up on the back of the transmission.
I've just adjusted the hand brake again and it's on 8 to 9 clicks before it holds.....and then it's on only a slight incline .
My lc was far better in that department on a same set up!
Who needs a hand brake any how........ Whistle If it dont work.......burn it!
Post #476468 22nd Apr 2018 2:15pm
You do when you go for an mot. Thumbs Up
Post #476469 22nd Apr 2018 2:35pm
