Home > Maintenance & Mods (L322) > Squeaking brakes |
Rocketuk Member Since: 10 Apr 2018 Location: Redditch Posts: 25 |
Hi everyone , two weeks into owning my 2011 L332 and found a annoying squeak as the car comes to a stop under breaking .
23rd Apr 2018 7:27pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 284 |
I had the same as you Rocketuk and it became embarrassing, it actually was the front pads. Changed pads = noise gone. Unless you did the service yourself have a look at the pads, don't assume somebody checked them
24th Apr 2018 6:53am |
Thanks for the advice
24th Apr 2018 10:41am |
depending on what alloys you have on you may be able to see through the spoke with a decent light, so again may save any graft unless you have to.
24th Apr 2018 12:00pm |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 88 |
I had the same issue and all the neighbours would know when I had just pulled up. It was in the dealers a couple of times and eventually they solved it by applying some anti-squeaking solution on the pads / discs that apparently they use for Land Rovers in the USA and it has just been introduced in the UK. That's what they told me anyway.... I need more help than most...sorry !! |
24th Apr 2018 1:55pm |
Thanks again for the replys
26th Apr 2018 7:47pm |
