Home > Technical (L405) > what is resetting the fuel trims?
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Car in at main dealers for some investigation work by Landrover Technical.
One of the things amongst others I've been told they are doing, is "resetting the fuel trims".
I'm fairly mechanically minded but never heard of this...anyone know what they mean or what it is?
thanks.
Post #477206 30th Apr 2018 11:32am
Montys 4x4
United Kingdom 2017 Range Rover Autobiography TDV6 Carpathian Grey
What engine do you have and current mileage ? interested due to my own issue with oil dilution with diesel during the DPF regeneration process on my 6 month old RR.
Paul Journey started in a LR2B at 16 and has incl. just about every Land Rover, Disco, RRS and Range Rover Vehicle owned or driven, I even worked for the company when it was owned by BAe - It must be a madness!!! because to add to my 4.4 TDV8 Westminister In Baltic Blue I bought a second L322 as a commuter bus, TD6 2004 Vogue in Oslo Blue with cream leather now both gone replaced with what could turn out to be my biggest mistake. Carpathian Grey ivory interior 3.0 tdv6 Autobiog. 2017
Post #477210 30th Apr 2018 12:40pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I would have though that you will have a short and long term fuel trim.
By resetting these LR can then see if there is an issue with your car if they are re-checked and are out of manufacturers specification.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #477212 30th Apr 2018 1:15pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
"Fuel trim" is relating to the air/ fuel ratio entering the cylinder head.
Post #477214 30th Apr 2018 2:18pm
Fleagle_UK
Laughing so in old fashioned speak they are simply resetting the mixture back to factory standard before the ECU "learns" optimum based on road usage / driver demand etc.
thanks all.
Post #477218 30th Apr 2018 3:37pm
Fleagle_UK
SDV8 - 29k.
Post #477219 30th Apr 2018 3:39pm
zarnd
thanks all.
To a point yes Laughing , but I presume that the car has an issue and this is one way to check your air/fuel ratio Alex
2007 M5 Touring
2004 SL55 AMG
Post #477220 30th Apr 2018 4:18pm
