Home > Maintenance & Mods (L322) > New L322 Owner - gearbox grief!
Mattv868
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
Hi Guys
Sorry if this has been asked 1000 times, but i'm in the predictable situation of a totalled TDV8 6 speed gearbox. She has 170,000 miles, and as far as i can see never had any gearbox love...
Currently dropped into 'limp' mode once warm. Had the diagnostics and all gears are incorrect, along with loads of other things!
It seems i have 3 realistic options:
Most costly (£4k) - Local trusted transmission specialist full strip down rebuild with genuine parts and re-fit.
Medium cost 1 (£2k) - Buy a pre-owned box from ebay (or similar) with 'warranty', and get local trusted guy to fit.
Medium cost 2 (£2k) - A company called LR TECHNIC has given me a very good price to take away, rebuild and refit.
Firstly, anyone had any experience with LR technic? A rebuild of mine with good parts seems the best option and cost to me???
Secondly, anyone have any thoughts/experience on buying a 'used' box, as i would rather give the local guy my money rather than an unknown?
Thanks, Matt
Post #477422 3rd May 2018 1:05pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
It's not the gearbox oil cooler / main radiator blocked is it?
Post #477423 3rd May 2018 1:10pm
odd that as they are generally pretty bullet proof as gearboxes go.
what are the faults its throwing? There is nothing that can't be fixed with a hammer😜😜
Post #477444 3rd May 2018 4:34pm
I'd be interested to know what the difference is between a £2,000 rebuild and a £4,000 rebuild.
Quality of work, gearbox knowledge, attention to detail, testing, etc.
To my rather cynical eye, LR Technic look like a jack of all trades with regard Land Rovers. They're not a gearbox specialist, so I would immediately question their ability. Then again, I'm no expert and would bow to the more knowledgeable folk in this regard. Si. <This is my name.
Post #477452 3rd May 2018 5:41pm
RRPhil
Re: New L322 Owner - gearbox grief!
Mattv868 wrote:
...i'm in the predictable situation of a totalled TDV8 6 speed gearbox.
Nothing predictable about that – the ZF 6HP26 transmission has an enviable reputation for reliability. Having said that, these are the known issues that occasionally affect this transmission :
1. Transmission won’t shift into 4th, 5th & 6th gears (E clutch slipping due to stator shaft bush wear/leakage)
2. Erratic gearshifts – particularly 3-4 (faulty solenoids)
3. Clunky 2–1 rollout shifts (requires software update)
4. Drops into neutral when accelerating hard/turning corner from stationary (clamp bolt for shift cable seized in shift lever)
5. Failure of output shaft spline through fretting corrosion (lack of lubrication during assembly at factory)
6. Clutch packs destroy themselves following fluid change and adaption reset (never reset adaptions unless mechatronic/solenoids are replaced)
Phil
Post #477453 3rd May 2018 5:42pm
jonbaobao
2007 Range Rover Supercharged 4.2 SC V8 Java Black
Dear Phil:
Mine seems to be #1 will it have symptom of surge in RPM then get stuck in 3rd? Mine also has fault code
RBM-Running Board
U0416-68 (2Cool Invalid data received from vehicle dynamics control module - Algorithm based failure - event information
( on 02-10-2019 12:41:02 at 88504 km )
Can this be related to the gear box problem? Does #1 requires a gear box rebuilt?
Thank you,
Jon
Post #535604 27th Nov 2019 12:03pm
