Home > Wheels & Tyres > 255/50r20 to 265/50r20? ok to add a little width? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3685 |
2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
13th May 2018 9:11am |
For what it’s worth those pictures with lines are all meaningless when comparing such small variations in height. All manufacturers tyres are different - many do not accord with true tyre sizes. If you compare Michelin and Goodyear’s - there is a massive difference not only in aspect ratio but also Width - historically Goodyear are also known for being wider and Michelin narrower size for size.
13th May 2018 9:18am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
i know I know thing is parking these shipping containers we drive isn't easy with a column of angry London couriers, vans, taxis, Ubers waiting impatiently while you line up. Narrow roads with HGV's shoving through mean you want your wheels an inch from the stone, no more. Any more and you risk loosing a mirror. Been sideswiped when parked more than once. Then you've got the competitiveness of parking spaces meaning aside of the above you've the extra pressure of claiming a space. Which means haste. A tricky one is the long reverse along the kerb because a space comes free back a bit. Left side you've got the kerb, right side a lorry that's just a bit too big. I try to reverse and keep the rears two inches off. Over a distance you can drift in and not notice because you're watching the other 3 corners. Or a double decker bus filling your mirror. I think I'm better now a year in, probably clocked up most scuffs in the first few months. I'll get the rims refurbed when I put new rubber on soon (my continentals are on 4mm) and once they're refurbed I want to protect them. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 13th May 2018 11:46am. Edited 1 time in total |
13th May 2018 9:24am |
Vogue yes sure it's only a rough guide. I think it's a good thing there's not much in it, I like the 275s that's probably what I'll go for. and not much in it because of all the variables as you say.
13th May 2018 9:28am |
Your best bet is to chose your tyre make and size and then get the manufacturers data - that is the best route and only truly accurate route. We have to do it fairly regularly for tractors as the front tyres are smaller than the rear and you have to match up the ratios - countless times we have found that size for size there are massive differences between makes 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
13th May 2018 3:34pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Photos of my Fatty in access mode with 255/55 /20. AT3
14th May 2018 2:17pm |
Proper RR tyres there ! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
14th May 2018 6:58pm |
Yep, they get used too. They're great tyres and a way more plush ride than the standard pirelli's.
14th May 2018 7:13pm |
For those that want the "filled arch" look here is the difference in the l322 wheel
14th May 2018 9:50pm |
Bit to much chunk for me Grofus, but
14th May 2018 11:18pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 350 |
How's the tyre noise on them, is it noticeable over the standard road tread tyres? |
15th May 2018 3:58pm |
No noise at all. If anything it's quieter as they soak the road imperfections up better. The ride is plush, easily as good as the several Jags I've owned 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
15th May 2018 4:09pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
19th May 2018 2:13pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Get tyres with rim protection... Also if you are changing the tyre size from what is OEM you will need to inform your insurance. Shouldn't really affect your premium, but they cant use it as a get out clause for an undeclared "modification".
3rd Jul 2018 6:26pm |
