Home > Maintenance & Mods (L322) > Rear wiper, is this correct
Nelly
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
Guys, just got the RR but I'm wondering if this is correct, the rear wiper doesn't return all the way up under the spoiler, but the sweep is equal
I have look through the wiki pages and on the www,but can't find the answer
I am taking it all apart tomorrow to find the rear wash wipe leak, so was going to look at this as well
Many thanks
Post #478035 11th May 2018 3:04pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Doesn't look right - mine certainly parks more neatly. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #478045 11th May 2018 4:43pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
It should tuck under the spoiler when in he parked position. It actually lifts the blade slightly away from the glass too, so that it doesn’t stick in freezing weather. Makes it awkward to swap the blade actually, requiring good timing to open the top boot at just the right moment to stop the blade mid-wipe. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #478046 11th May 2018 4:45pm
Nelly
I did think it should, so not sure what the issue is now, is /should the sweep be symmetrical?
Post #478047 11th May 2018 4:48pm
steveball
Not symmetrical. Hopefully the glass is dirty enough for you to see the wiper sweep on mine.
Post #478048 11th May 2018 4:52pm
Nelly
Yeah I can see that thanks,, I don't think this wiper has as much movement
Post #478050 11th May 2018 4:54pm
mjdronfield
I can only suggest removing the wiper arm when it’s in the park position and putting it back on so it’s under the spoiler. Think you have to remove the spoiler to get to the nut, so might be best doing when you investigating wiper motor issues or such like....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #478057 11th May 2018 5:23pm
Nelly
OK will do, I'm taking the rear apart tomorrow anyway so will have a better look
Post #478060 11th May 2018 5:28pm
