Home > Maintenance & Mods (L322) > L322 suspension faults |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
If you surf over to our sister forum for Range Rover Sports www.RRsport.co.uk I know the same fault has been dealt with several times over there in the last 18 months - if you use the forum search function here and over there and on Disoc3.co.uk you will find loads of posts about similar problems.
11th Feb 2011 1:53pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
My guess is ita only really likely to effect the dynamic stability control. I.e. the car will be less stable in an "exciting event".
11th Feb 2011 2:40pm |
Out of interest, did you replace the Yaw unit yourself or get a LR garage to do it? Reason I ask is because LR dealers have been known to charge for replacing parts they haven't...
11th Feb 2011 3:40pm |
lloydyboy Member Since: 11 Feb 2011 Location: north east Posts: 10 |
Thanks for your input Elpeede, Tim and Dan. Bought own YAW unit and had mate who is BMW specialist to fit in his garage. I told him about these forums, but he said to steer clear cos they can lead you away from the prob, but he is starting to come round and listen to what you guys are saying about the all the history you have between you all. Battery is new when I bought the car but I will make sure its the correct one for the job next time im in the garage.Tim I went into the offroad sat nav couldnt find the settings you where steering towards! Elpeede do you you know your ex neighbours phone No.!! |
11th Feb 2011 6:09pm |
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 |
I had the same errors, and it was traced to a speed sensor on one of the front wheels ...£17 later and its gone
11th Feb 2011 7:08pm |
Cheers bogie, My mates got the bosch testing lap topy thing, is there a better one to test the vehicle with!!. He said if it were a switch,sensor etc it would tell him which one.All faults were cleared and it keeps coming up YAW (LR language Stability sensor). Its a horrible wet rainy ,drizzly night here in durham, tossed the coin up to see if pub or tescos, staying in, trip to tescos. On my way to tescos, sat in the RR turned the key to pos 1 waited till all the clicky noises went, turn to pos 2 waited till all the clicky noises went turned ignition on, started engine and hey tesco (presto) no faults, HDC hung on in there for a few secs then went off. Did exactly the same when i fueled up with boys fuel at tescos and hey, no faults, cant wait till morning to see if it does it again (just like christmas so excited) Just thought (clicky things) is there any relays that energise when the door opens or when unlock and when turning the ignition through its possitions that would be connected to these sort of probs. |
11th Feb 2011 9:32pm |
a generic reader for a Bosch ECU will only give generic manufacturer codes as per whatever BMW use...the LR full diagnostics gives a lot more detail and specifics usually
11th Feb 2011 9:44pm |
Cheers bogie, you are now saying the same questions I was asking, all along I am thinking/asking this is a silly switch, sensor or bad connection (worn cable) combination, I have nearly got my mate on my side and to stop listening to his lap top. I'm going to have him lead me to the correct person to have this sorted. He has connections in LR and £300 i have just spent!! And all this started with the bad weather, like most of the forum reports on other sites, with similar faults. When I was working, the factory was run through computer systems and when there were faults we had electrical bias techs who were trained to read the faults (break downs etc) on ladder diagrams, on the computer screens, once you knew what you were looking at it was quite simple to see what was faulting, thats what i have been asking for and need. These are our motors not LRs so why is it top secret that they have the diagnostics, there I have snapped, b----cks |
12th Feb 2011 1:09am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Here's what I found my problem was, worth a check...
12th Feb 2011 1:34am |
Cheers Richcl, cheers for that, Ive been through the forums and found your faults and it was one of the first things i looked at. But im going with Bogie on this one, going round to the garage today to give my friend a little push to have this sorted. On the bright side of things it certainly stops you getting board, wish I could get my hands on a ladder wiring diagram. |
12th Feb 2011 11:01am |
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 |
Yaw sensor needs calibrated once fitted 2011 4.4tdv8 vogue black with black
12th Feb 2011 1:11pm |
Cheers Irdaft. Getting back to my trip to tesco the other night, I now enter the RR insert key into the ignition turn to poss 1 and wait a few secs turn to poss 2 wait a few secs. ignition on and wait till inspection complete, ABS light goes out etc and hey tesco NO FAULTS, been like that from friday night now me thinks that when I wasnt doing that and jumping in turning the key starting the engine, turning the lights on and so on, do any of you think that there was a drain on battery (recently new battery)and not enough power for the electronics to do their check/cross checking and go into fault!!! Its so nice to get in and drive without the dash flashing at you. |
13th Feb 2011 12:27pm |
Back to normal, it faults then doesnt fault, it faults then doesnt fault. ,It will have to go into LR. |
14th Feb 2011 7:20pm |
andrewcooke1720 Member Since: 14 Feb 2011 Location: Co Kerry Posts: 28 |
i've been getting the fault message air suspension inactive, but it coincides with the car not starting due to a flat battery. new battery ordered so i'll keep on eye on things and update the post if i ca remember to do so. |
17th Feb 2011 2:46pm |
