Home > Maintenance & Mods (L322) > Rear Light Cluster |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7724 |
Yes - undo the 2 on the inside and it should slide towards you - may need a little leverage if its been there for a long time. |
13th May 2018 8:15am |
There is two prongs on the back of he light which go into grommets on the rear wing. Take out the bolts and the light basically slides out backwards. The indents should be on the light on the rear wing edge. bit not sure if there are any on the 2011
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3951 |
I cut a thin wedge out of softwood and then tapped it in the gap to gently drive the lights forward and off the clips. No damage to anything. I would suggest greasing the clips before putting the lights back in place, makes it easier to remove next time. |
13th May 2018 8:24am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
The socket into which the ball joint slides (on my 2004, at least) can become brittle with age. Mine broke when levering the light out. Ron B. VK2OTC
13th May 2018 8:28am |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
Thanks for the quick reply's guys, I will go and sort it while we have sun light in the north |
13th May 2018 8:31am |
Is the unit fully sealed, or do you just undo the 4 t20's and it opens? |
13th May 2018 8:49am |
Left the bolts, used hot air to go through the 2 holes after removing the rubber covers on the back, all dry, resealed and fitted back, cheers guys |
13th May 2018 12:13pm |
