Home > Technical (L322) > E G R PROBLEMS
disco 3.5
E G R PROBLEMS
hi all, my engine management light has come on, took it took a local garage for diagnostic check and the code came up as e g r fault, have been advised to giv e the car a good long run because they believe the egr dont like me just doing short little runs all the time, the engine management light was off when i picked the car up so i head off to give it a good run. 5 minutes down the road descided to open her up a bit soon as i put my foot down the enginemanagement light came back on, the garage said if this happens i will have to replace both egr because they wont know which ones at fault, is this good advise, if it is how much am i looking at to replace them many thanks LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #480847 13th Jun 2018 8:30pm
Meerbusch
Had the same problem at 2007 TDV8, only cleaning was best and cheapest method, cleaning also the potis inside the EGR, 10.000km without any lights...., seven hours job, described here in wiki.
Best rgs, Uli TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #480856 13th Jun 2018 9:33pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
have a remap and blank the EGR and its cooler , you wont regret it and its probably cheaper to do too
Post #480858 13th Jun 2018 9:43pm
rar110
Try induction cleaner. I used Revive. It’s available in uk. Then remap to disable EGR. ______________________________
Post #480859 13th Jun 2018 9:47pm
rar110
http://www.autosessive.com/blog/index.php/...-reviewed/
Otherwise you might need to specifically clean the EGR as suggested above. ______________________________
Post #480861 13th Jun 2018 9:51pm
disco 3.5
is remapping it legal. will it pass the new mot
mod edit, please use lower case when posting LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #480862 13th Jun 2018 9:54pm
bembo449
take you caps off please pal , no remapping is not illegal and wont effect MOT
Post #480863 13th Jun 2018 9:55pm
disco 3.5
cheers bembo 449 having it mapped out and blanked not affect the engine ? LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER
Post #480864 13th Jun 2018 10:01pm
bembo449
well yes it will ,better performance , better economy and smoother running , there are no downsides if you do the full mod pal Cool
Post #480865 13th Jun 2018 10:04pm
Paul thornton
If it's a 3.6 then your best option is to have the EGR's removed and blanked and then the car remapped to accommodate.
If they are starting to stick then there's an inevitable chance that they will break up inside and the engine will digest them. Then you will have a big problem.
Mot is just a visual inspection so as long as it looks like it's got EGR's then you will be fine.
Post #480878 14th Jun 2018 8:58am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
MoT testers are not allowed to remove covers. As long as the top engine cover is on, there is no way to see if you have EGRs enabled or not.
BTW, for the original poster, the engine diagnostics (LR or IID) will tell you exactly which EGR is failing and with what.
Post #480900 14th Jun 2018 3:17pm
