Home > Technical (L322) > VIN decoded - some questions about what was revealed |
Kiwimac Member Since: 15 Jun 2018 Location: Wellington Posts: 48 |
I put my RR VIN through one of the online decoders, which came up with a long list of the options etc fitted on the car.
16th Jun 2018 11:16am |
Thanks - that makes sense.
17th Jun 2018 4:44am |
Beausoleil Member Since: 29 May 2018 Location: London Posts: 7 |
On EU BMWs that's just a sentinel that flashes to signify the alarm is set. If yours doesn't flash, I suppose it could be an IR receiver. The test is, can you unlock your car without it 'seeing' your remote. |
17th Jun 2018 10:30am |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
Can I ask which online decoder you used, as I have tried the recommended Topix system and it could not decode anything other than basic information? David
17th Jun 2018 10:36am |
I believe it was vindecoderz.com or something very similar. It was a little jumbled and some of what came back was in what looks like Russian. |
17th Jun 2018 10:42am |
Thank you, I must admit I did look at that site but got nervous about bugs/hacks etc.
17th Jun 2018 10:52am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Google Translate does a pretty good job of handling all the Russian text, but put it in in chunks as there is a text number limit. .
17th Jun 2018 11:19am |
Way ahead of you Joe and yes it was surprisingly good. None of it told me anything much, though and most was just repeating the English. |
17th Jun 2018 11:25am |
