Home > Maintenance & Mods (L322) > Diagnostic advice required |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
If you put the sensors on and listen closesly to each one you should hear a clicking sound. If one doesn't click thats the faulty one. If one doesnt work the whole lot doesn't work but they will still click. Current 2007 TDV8 Vogue Buckingham Blue |
27th Jun 2018 4:41pm |
johnb8538 Member Since: 15 Sep 2016 Location: Glasshoughton Posts: 71 |
Thanks for that. Already tried the “clicking” tactic then spent days trying different ways to hear the noise which apparently is supposed to be quite audible. Found another post stating that in later models no audible sound could be heard and that any fault in the system shuts the whole thing down. I’m assuming a diagnostic will state which part of the system is down e.g. sensor or control unit.
27th Jun 2018 8:43pm |
No problem that worked for mine but its a bit older. You should be able to wiggle the wires without removing the bumper if its the same as the 07 if you get under the car and squeeze your hand in. If its intermitent you would asume it could be a loose wire so may be able to try that to give a clue. Current 2007 TDV8 Vogue Buckingham Blue |
27th Jun 2018 8:58pm |
Another thought is to call green oval for a quote they are an Indy and are off the m621 near ikea in leeds so not to far away. If they repair it im sure they wouldnt charge for a diagnostic too but dont hold me to that! Current 2007 TDV8 Vogue Buckingham Blue |
28th Jun 2018 6:49am |
Ill try the "wiggle method" before ringing the indy guys,its going to be something daft I bet.
28th Jun 2018 10:23am |
Just called Oval £45 plus vat for diagnostic and happy for me to take the information and walk away rather than force me to buy their parts. Lets see what it is... |
28th Jun 2018 11:18am |
Good luck with it hope you get it sorted! Might be worth investing in a diagnostic tool like the iid one as a few trips at £45 plus vat and its paid for plus they retain good resale value too! Current 2007 TDV8 Vogue Buckingham Blue |
28th Jun 2018 5:00pm |
Well after having a diagnostic done it was discovered to be the control module. The garage took one from a freelander and it worked no problem. They suggested £130 for a brand new dealer replacement. There are several available a lot cheaper online and as I'm likely to change the vehicle in September it seems the best option. I'm just not sure whether another freelander one for example might have some different "settings" etc.
16th Jul 2018 2:24pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
https://www.ebay.co.uk/itm/RANGE-ROVER-DIS...SwEaNa3t1h
16th Jul 2018 2:42pm |
haha thank you I'm already watching this!!
16th Jul 2018 2:56pm |
That a bit shaddy! They should be upfront with the charges poor show from a forum sponsor. They seemed ok when i used them but will be wary now and not recommend them again. Current 2007 TDV8 Vogue Buckingham Blue |
16th Jul 2018 7:32pm |
Thanks for that but I’m not here to bash anyone. It was a great looking place and everyone seemed knowledgeable and polite, just a rubbish bit of communication I wrongly assumed was goodwill . I could have disputed it at the time but you realise quickly of course they are there to make money same as any other garage, they aren’t your friend doing you a favour. The labour charge was the same as the JLR dealership nearby so they didn’t actually do me any favour at all. You live and learn. At the end of it all I now know what it is and it’s an easy fix. |
16th Jul 2018 9:45pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
From my (thankfully limited) experience of JLR workshops I’d be surprised if they would try a component from another car.
16th Jul 2018 10:32pm |
Just to close this off.
3rd Aug 2018 9:26am |
