Home > Maintenance & Mods (L322) > First of many questions |
Please fill in your profile so we know what car you have got!
30th Jun 2018 10:09am |
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 |
Thanks Joe for a quick response
30th Jun 2018 10:32am |
very smart
30th Jun 2018 10:39am |
thanks again
30th Jun 2018 10:57am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
Your offside exhaust leak will be a crack in the front edge of the cat where the manifold comes down from the engine and enters the catalyst. Well known fault but can be welded for c. £50
30th Jun 2018 5:43pm |
dolphinboy
30th Jun 2018 9:13pm |
NOt an expert in this but know from others they have had probs getting bits off etc. due to age and corrosion.
30th Jun 2018 11:33pm |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 |
Oil leak is probably the valve cover gaskets - common problem, replacement seals are about £30 but get them replaced by an independent specialist - could also be the PCV valve causing pressure and forcing oil under the seal. |
1st Jul 2018 1:23pm |
