Home > Maintenance & Mods (L322) > Windscreen buzz/vibration from lower cowl...
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Morning all.
I've got that awful hum/buzz coming from the bottom edge of the windscreen at anything over 55mph. From what I can tell its the usual vibration of the rubber strip, but is it possible to fix with the windscreen in place? Don't want to make anything worse for when the inevitable happens and I need a replacement. Is it as simple as gently prying the rubber strip away from the glass and squeezing in a thin bead of sealant? If so what's best to use?
Thanks in advance. Life is what happens while you�re making other plans.
Post #482403 2nd Jul 2018 10:42am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
On mine it was the actual scuttle panel under the windscreen rather than the windscreen seal itself. Mine was lifting ever so slightly in the wind above 55mph- I just put some sealant around it and it went away. Also worth checking that the cabin pollen filter tabs are all locked in properly, the plastic poppers on each end are fully home and the rubber strip along the top between the panel and the bonnet is in place too. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #482440 2nd Jul 2018 7:21pm
Knightmare
Thanks for the tips. It was definitely the rubber strip at the top of the scuttle...bit of sealant and all appears ok Thumbs Up Life is what happens while you�re making other plans.
Post #482511 3rd Jul 2018 6:18pm
dirtymonkey38
What does it sound like, if your able to describe it? I have an irritating rattle in the cabin that sounds like its coming from the lower speaker grill on the passenger side. Hate noises you cant track down and was wondering if maybe something outside the car. 2011 RR Autobiography 4.4 TDV8
Post #482514 3rd Jul 2018 6:29pm
nicksaab
Noise coming from lower passenger door speaker was the lower front wing panel not clipped in place outside on mine. Also check the side grilles are screwed in tight as they can rattle too Current Fleet:-
Post #482525 3rd Jul 2018 7:24pm
dirtymonkey38
thanks, i will check them. Although I've not noticed it today after i spotted a loose bracket in the door. Its the plastic bit that goes from the door to the wing with a male hex nut on it. Tightened it up, and so far all ok....now I need to fix the rattle on the centre console. Really need to get myself a workshop manual for all the odds and sods that need doing. 2011 RR Autobiography 4.4 TDV8
Post #482639 4th Jul 2018 7:38pm
nicksaab
Centre console rattle - yep been there. I found an old tracker unit in mine which was rattling away! Current Fleet:-
Post #482640 4th Jul 2018 7:40pm
