Home > Maintenance & Mods (L322) > PCV replacement |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 |
Going to get mine replaced (04 4.4 petrol) and was wondering if I should buy anything other than the valve itself - recall hearing that the connecting pipework often needs renewing as well? Anybody know which pipes and where is best to buy them? |
9th Jul 2018 4:39pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
Yep there are 4 pipes you will probably need
9th Jul 2018 5:00pm |
Many thanks nicksaab - most helpful - managed to get all but one hose in blue Silicone for under £30 the lot. |
10th Jul 2018 11:36pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Just a little caution -- my hoses needed to be replaced so thought I'd do the valve as well -- so I set off to my trusty mechanic with all parts in hand -- he's been mechanicing for 40 years, and I have 100% faith in his ability!
11th Jul 2018 10:52am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
I can't find the PCV in MicroCat. Would you know the part no.? Ron B. VK2OTC
12th Jul 2018 7:40am |
Thanks for the tip -- a job for another day..............
12th Jul 2018 9:57am |
Do the actual valves wear out then? - would I be safer just changing the pipes or would that be false economy - considering suggesting to my mechanic to try removing the Torx but if one strips then abort the job and just do the hoses.BTW - bushy30 if you want to sell your spare please let me know how much you would like for it. |
12th Jul 2018 11:01am |
Thanks Bushy. I can see why I couldn't find it - the item's images in the emissions control parts page and the inlet manifold parts page are totally different.
12th Jul 2018 11:04am |
Storey Wilson suggests they should be changed. See Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
12th Jul 2018 11:05am |
Bruno, it's the rubber diaphragm that breaks down, so yes -- Storey does say that you can swap them if the unit you have can be opened -- my replacement couldn't be opened, so haven't tried the one on the car -- I ended up simply changing hoses and cyclone.
12th Jul 2018 11:56am |
Duckworths were asking £112 for the valve and £12 for the thin pipe - ebay trawling got both items, inc postage, for under £60 - running my car on a tight budget so every penny counts. |
12th Jul 2018 4:48pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
Have a go doing the thermostat mod / upgrade there’s plenty of info here on the forum. Essentially it’s a lower temperature thermostat that opens earlier and prevents overheating, there are a lot on here that have carried out the mod and had absolutely no problems. It’s a relatively easy job and if yours is goosed anyway.......... ______________________________ Simon ______________________________ Range Rover Classic 3.5 efi - Gone Range Rover Classic 3.9 efi - Gone Range Rover Classic 4.2 LSE - Sadly gone Land Rover 110 3.5 - Gone Range Rover P38a 4.0 SE - Pleased it's gone Range Rover P38a 2.5 DHSE - Just sold Range Rover L322 4.4 v8 Petrol - Current |
12th Jul 2018 5:07pm |
Thanks Simon, and good idea -- apart from the fact that I ordered the thermostat and had it delivered already
12th Jul 2018 5:18pm |
That’s a shame the mod really does take the strain off the engine, I’m not exaggerating when I say that the first time I started the motor and took it for a run I really could tell the difference.
12th Jul 2018 5:22pm |
