Home > Maintenance & Mods (L322) > Thermostat and general coolant system conundrum
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Ok, so changed the thermostat and got an airlock, are they difficult to bleed?
And........ Here's a new one for you all who like mods, the old thermostat had been modded with 8 small holes drilled through the closing disk, that's a new one on me!
Post #483599 16th Jul 2018 8:42pm
Bushy30
So the machine was left overnight to settle, topped up this morning, left all day and tried this evening.
All seemed well, temperature cam up as normal, needle at 12 o'clock, sat there, didn't move -- top hose hot, bottom hose (from the stat) cold, nice warm air coming through in the car -- after being stationary for a while, 5 or 10 mins, fans 'cut in' and check the bottom hose all hot, all good!
Leave to idle, all good
Put the aircon on at idle -- all bad! needle almost of the guage straight away Sad
Hold the throttle at 2000 revs needle comes back, ok idle again, temp goes up, aircon off, temp comes down -- OK so this needs a road test, 300 tards up the road needle of the scale, 300 yards back, open the bonnet to see what's going on, coolant out of the filler cap -- hmmmm, no hot air in the car anymore either
And then.....................
The top hose blows it's connection on the block with the obvious immediate loss of water.
Now I'm really hoping you learned chaps and chapesses here can help with this?
Thoughts -- is the rad blocked?
is the electric fan 2 stage and I'm only getting 2nd stage? ie. not running at slower speed when needed?
Is the viscous working as it should (seems to be)
Or, worst case have I got block pressure in the coolant system?
Really need some help here please!!????
Post #483672 17th Jul 2018 9:12pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Sounds like you still have air in system they can be a swine to bleed and will destroy expansion tank and top hose check bottle cap and if 200 change for 140 do not overfill fan won't work if air in system as it is not heating due to lack of water in system.make sure you have no leaks anywhere and change stat hope you fix problem
Post #483675 17th Jul 2018 10:43pm
Bushy30
Thanks Rik
Post #483677 17th Jul 2018 11:01pm
Bushy30
Further update, filled it with water tonight, tested for exhaust gas at the expansion bottle, all going well for 10 mins, then the dreaded colour change.
Ok, so I need to get the heads done, any recommendations for Oxfordshire?
Post #484183 23rd Jul 2018 7:43pm
Have you had the radiator out yet and checked it for blockage ? .
Post #484184 23rd Jul 2018 8:37pm
Bushy30
No Joe, not yet, but gases in the water can't be good can it?
Post #484190 23rd Jul 2018 10:27pm
rik
Is she on lpg?
Post #484192 23rd Jul 2018 10:31pm
Bushy30
Hi Rik, yes indeed, lpg! And we have been testing with it running lpg if that makes a difference?
Post #484193 23rd Jul 2018 10:51pm
rik
Vaporizer can leak gas into water as it uses hot water to vaporize gas mabe run her on petrol for a while and check again can be a common fault .Not to expensive to fix better than head gaskets
Post #484194 23rd Jul 2018 11:02pm
rik
Prob need to drain her and put fresh water in if she is contaminated keep gas off
Post #484196 23rd Jul 2018 11:04pm
Bushy30
Thanks Rik
Post #484197 23rd Jul 2018 11:38pm
Bushy30
Hi All, please does anyone have any recommendations for who could do my heads for me please? Obviously the closer to me the better!
Thanks Smile
Post #484845 31st Jul 2018 10:39pm
ChrisJJ
United Kingdom 2002 Range Rover Vogue 4.4 V8 Alveston Red
Bushy30 wrote:
Now then, to the fans
I thought I'd read the electric fan cuts in first, followed by the viscous -- in fact I'm sure Joe90 said he'd removed his viscous in favour of just using the electric one.............. or have I got that all cart before horse?
A viscous fan will always spin as it's attached to the water pump which is driven by the serpentine belt. You can stop it using something that won't break it such as a rolled up newspaper. When the radiator get's up to temperature, the viscous fluid heats up and locks the fan clutch and then fan will spin at actual engine speed. Don't try and stop the fan when the radiator is up to temperature though and the clutch has locked.
Post #487675 31st Aug 2018 9:41pm
