Home > Maintenance & Mods (L322) > Rear susp top joint movement |
Squeaking could be coming from the inner wishbone bolts - these are "built dry". Lower ones easy to get at, upper ones less so in order to remove bolts and grease up.
15th Jul 2018 9:36am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
Graeme, the joints are like a rose joint (see my pix at http://www.fullfatrr.com/forum/topic13469-15.html (scroll down).
15th Jul 2018 10:41am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
Thanks Joe. The squeak is definitely coming from an outer joint and I'm fairly sure the bottom joint is the source. With minimal load on the top one I can cause the squeak by moving the top one sideways a little using a large screw-driver but no noise from the top.
15th Jul 2018 10:43am |
Thanks Ron for the info but my son has lent me his bush press set.
15th Jul 2018 10:55am |
Also check the toe bar for movement at both ends, if this is shot, it can allow "natural" movement in the rose joints .
15th Jul 2018 11:15am |
Thanks - will do. |
15th Jul 2018 11:44am |
