Home > Maintenance & Mods (L322) > Second of many questions |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16146 |
Thats not a standard JLR westfalia tow bar sir...
15th Jul 2018 5:39pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
It's a brink like mine.
15th Jul 2018 5:54pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
The Leather Doctor sells on ebay - exact colour match and kit will clear that up with minimal effort. |
15th Jul 2018 7:55pm |
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 |
thanks chaps for your replies, I will have a go at the tow bar at the weekend,
17th Jul 2018 4:17am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Your interior colour looks the same as mine & is listed as Jet / Charcoal (TCX). Loads of kits on ebay just make sure that you have tinters with it, as I had to add a load of black to match my colour. |
17th Jul 2018 7:05am |
Speak to Stacie in the land rover customer relations section on here and she will be able to provide you with a build sheet |
17th Jul 2018 7:18am |
cheers Paul
18th Jul 2018 4:22am |
well had a go at the tow bar, no luck, couldn't see a catch at the back as suggested so tried to undo the bolts only to find the bolt head was starting to turn but no bolt movement so stopped instead of shearing it off!
25th Jul 2018 6:20pm |
WOW what a difference, what did you use, looks brilliant |
25th Jul 2018 8:24pm |
If I remember tomorrow, I'll get my tow ball out of the boot and show you what I'm on about. |
25th Jul 2018 10:14pm |
Thanks Highroller
26th Jul 2018 4:51am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6646 |
These guys do specific kits for RR colours, so matching shouldn’t be a problem
26th Jul 2018 8:21am |
Definitely give mine a go next month when I do the oil change. |
26th Jul 2018 9:30am |
