Home > Maintenance & Mods (L322) > Rear Diff Oil fill plug, Part No & Position?. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Just done mine but not sure. Neither is Dan because when (if) you order from Duckworths, you may get the wrong one like me and one other chap.
15th Jul 2018 9:49pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
Why change the diff plug? In over 55 years of driving and maintaining cars, I've never need to replace a diff plug. Ron B. VK2OTC
16th Jul 2018 4:31am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1269 |
16th Jul 2018 7:05am |
Something to do with the magnets?
16th Jul 2018 7:11am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
No magnets on the filler plug, and I also have never replaced one. when putin plugs back in use some plumbers teflon tape. |
16th Jul 2018 9:28am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Thanks for the reply guys. Yes if it comes out ok then I can put it back in, however it's pretty rusty under there & for the cost of these I'll like to replace it or at least have a new one handy.
16th Jul 2018 11:09am |
I hadn't thought about rust - it's not something that comes to mind here - Land Rovers have an in-built rust prventative system. Ron B. VK2OTC
17th Jul 2018 9:47am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
up to vin 2007
17th Jul 2018 10:02am |
Thanks Lounge_on_wheels. That sure looks like it from what I can see (Obviously it's Not been out for a long time as heavily corroded).
17th Jul 2018 7:48pm |
UPDATE:- Still struggling to find this plug & remove the old one FTC5431 or TYB500110 is too big (21 mm ).
28th Jul 2018 11:36am |
Can you get a cold chisel on it to get it going round ? .
28th Jul 2018 2:19pm |
Cheers Tim, Might have a go at that.
28th Jul 2018 2:35pm |
Have you asked Dan at Duckworths, supplied VIN, etc. Usually works, although I see what GGDR was saying above. .
28th Jul 2018 3:41pm |
if you gonna bang something in, try Torx bit, oversized, it will have more grip, or cut a groove in the bolt with dremel like tool and use screwdriver with wrench.
28th Jul 2018 6:15pm |
