Home > In Car Electronics (L322) > AUX-level fix! |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 56 |
Hi all,
17th Jul 2018 11:52am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
looks well made..good find sir ... - .- -.
17th Jul 2018 12:14pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Henrik07, do take some pictures so we can follow |
17th Jul 2018 4:31pm |
I will, when I get around to the permanent install. At the moment, it's all hanging off the cig lighter. |
17th Jul 2018 8:55pm |
paulgo Member Since: 26 Mar 2018 Location: Durham UK Posts: 10 |
I also meant to ask where you've got this placed i.e in the loom before the aux socket in which case how did you wire it in? Thanks! 2007 Range Rover Vogue 3.6 TDV8 |
9th Aug 2018 9:57am |
Hi,
9th Aug 2018 10:16am |
Ah - got you, thanks. Did you just unsolder and replace the phono sockets on the board? I think I'll definitely give this as go 2007 Range Rover Vogue 3.6 TDV8 |
9th Aug 2018 11:05am |
No phono sockets on the board. It's a simple 3-pin in and 3-pin out. I was lucky enough to have suitable connectors on hand, but if you don't, just solder your wires to the pins directly. R, L and gnd is printed on the board, so it's pretty foolproof. For a temporary install, just get a mini jack extension cable and snip it in half, soldering each end to the amp board and a ciggie-plug to the power input. |
9th Aug 2018 4:53pm |
Sorry - I think I veered off somewhere and have been thinking of a slightly different board - but looking at the one you actually used I get what you mean!. cheers 2007 Range Rover Vogue 3.6 TDV8 |
9th Aug 2018 6:41pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Did this get finished? trying to get my head around what plugs in where....I'm planning on wiring in an amazon input device into the rear aux port (probably soldered to the back of the panel). does this board need wiring to the cars amplifier or does the board amplify? 2011 RR Autobiography 4.4 TDV8 |
18th Jun 2019 10:34pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
What about this one already to go on?
18th Jun 2019 10:51pm |
Great find sir |
19th Jun 2019 12:15am |
finchi Member Since: 25 May 2017 Location: Hampshire and Cheshire Posts: 120 |
https://www.ebay.co.uk/itm/RED-Coiled-3-5m...SwM~taX2Kw
19th Jun 2019 9:14am |
The board amplifies. It raises the level of the output of your mobile device to where it better matches the sensitivity of the aux input. I have yet to make the input permanent, looking at bluetooth module to go with it.
9th Aug 2019 4:20pm |
