Home > Maintenance & Mods (L322) > Replace Heated O2 sensor
PaulCee
Hi,
I am looking to change the heated o2 sensor pre cat. Number 2 in the picture.
Had a quick look this morning, took of the shield below gearbox, and had a look to see what was what. There is the temperature sensor (number 3 in picture) quite visible and easy to get to, but the o2 sensor is up in there and seems quite difficult. Even the plate where the electrical connector hides behind has a difficult bolt to undo. This is probably because the exhaust is in the way, but bolts on exhaust very rusty and would prefer to change with this on if possible.
Just wondered if any one else has done one?
Thanks guys. 2011 Range Rover AB 4.4 TDV8
Post #670073 29th Jul 2023 7:06pm
